1 - 12 of 12 Posts
Hi everyone, there is a strong possibility that I will be replacing my Holley electric fuel pump soon. I just filled the tank before I began thinking about doing this. I know I can siphon or drain the tank via the plug, but I was wondering if there was another way?? I don't need the gas running all over the place and I know some members get real creative with the way they do things. I was hoping someone had a little trick in changing out electric fuel pumps. Thank you, Carmine.
Had a look in the manual, lo & behold you guys are correct, dont know why I thought 55/56 did not have a drain plug heres a pic from the workshop manual that shows the plug.
You may have been thinking of the rear axle Angelo
If you are looking to drain the tank, why not remove the output line to the carb and put a hose on the outlet side or disconnect the line up front and turn the pump on to drain the tank. Just have enough fuel cans on hand:anim_25:
Discussion Starter · #12 ·
Not a bad idea at all. Might just try that. Just left the garage and tried loosening the drain plug. This is a new tank and the plug wouldn't budge at all. I thought I saw the entire tank move a little so I stopped. Tried siphoning the gas using at least a 5'-6' piece of garden hose. For whatever reasons, the end of the hose in the tank never came in contact with the gas. I know there has to be at least 3/4 a tank of gas. So, I quit for the day. Tomorrow is a new day.
1 - 12 of 12 Posts
