1 - 2 of 2 Posts
I'm trying to carefully remove my rusted out wheelhouses with one section remaining. Does anyone know if that section directly under the "C" pillar is spot welded?
The area is clean although I can't make out where the factory would have made the weld joint.
Sort of at a stand still.
Everything on the body is spot welded.
One problem area is very top of the wheelhouse. There is a bulkhead and rubber seal there. In replacing the quarter panel on my 2 door sedan, the bulkhead was pretty rusty, and there was a hole about the size of a quarter in the inner vertical panel above the tub. There was absolutely no other rust in the tub area on my car. I only noticed it after I cut the original quarter off. I couldn't see it from inside the trunk because of the hinge box.
1 - 2 of 2 Posts
