I'm slowly starting to resume work on a long-dormant restoration ('55 Bel Air 2 door sedan, 6 cylinder, 3 speed, low mileage original car). When I bought the car, it ran okay except for a really rough idle. I rebuilt the carburetor, which mostly solved the problem, but it would still occasionally run rough momentarily at idle.
Having recently pulled out all kinds of goodies as display items for a "Carburetors 101" session presented by a club member who spent his career designing Rochester carbs and fuel systems, I got motivated to dig into this carb and see if I could solve the rest of the problem. In the process, I discovered what appears to be a manufacturing defect and an important part missing from the carb rebuild kits of the era. But, I digress...
Now, being a reasonably intelligent individual, years ago, I ran the engine out of gas before pulling it. But, as I just found out the hard way: a) running out of gas doesn't mean there's no gas left in the carb; and b) said remaining gas may not evaporate.
What gas had remained in the carb had turned into that rock-hard varnish mess. I now had a gummed up carb where the only thing that still moved was the choke plate. The gaskets were stuck. The float was stuck to the bottom of the bowl. The accelerator pump, power valve piston, check balls, and throttle shaft were all stuck solid.
Oh crap.
But, I was able to get everything freed up and cleaned up without damaging a single part. So, I thought I'd share how I approached it.
Oh crap.
