1 - 11 of 11 Posts
I have not posted that much, but I check this site multiple times a day. I have made the decision to do a frame off restoration of my 57 hardtop -- was my dads.
I pulled out all of the regulators. They are pretty rusty. Classic Industries runs 20% off all the time. I can get each of the window regulators for approximately $80.00. I noticed one post about Danchuk reproduction regulators having some issues. This makes me a little nervous. I am torn between trying to restore my old ones or getting the reproductions. By the time I pay for blasting, etc., the cost to fix the old ones may about the same or slightly more than simply buying the ones from Classic Industries. I was hoping to get some opinions from the board on both options.
If they're working smoothly then there's no reason to replace them. As far as restoring them, I'd just soak them in solvent for a day, then dry them off and put lithium grease on the moving parts. Surface rust isn't going to hurt anything and will be hidden anyway.
If you can find someone with a sandblaster that would be best. I had access to one and blasted all mine then repainted and greased everything good, they work like new.
If they are still working, don't waste your money on repo's. Use a wire wheel on you grinder or a wire brush and a little elbow grease they will come up fine. If you are doing a frame off resto you will need to save as much money as you can, good luck.
Good luck with your restoration. In my experience the restored OEM provides better service than the repop and is better quality.
Keep what you have.
mine were all frozen. sand blasted and oiled them up. 3 out of 4 are good to go. the drivers is missing a few teeth so that will get replaced with a repro. ill post how well the new on works when I get it.
Thanks for all the responses. I am leaning towards blasting mine. Should I paint them?
1 - 11 of 11 Posts
