I seem to have a lot of questions,but for those who have alredy done,it may sound easy.What is the correct way to remove the rocker panel molding.
Angel. Wish I could help... I am on the other side... getting ready to install rocker molding.... I am sure someone on the board has done it before. Maybe its the same as removing the paint-line molding. Anyone know?
Ther should be a threaded stud sticking out inside the lower fender,remove the nut, and another one in the front of the rear wheelwell. After that they should snap off of the clips that are in the middle area,3-4 of those. I`d unsnap them from the lower part of the trim,Terry.
A little knowledge can go a long way.Thanks for the info.Whoever replaced these didn't put the one in front with the stud on one side.I went to the side that had the stud and when I removed the nut,it popped right off.Thanks once again
