Brought my stock front drums that were still rivited to the hubs to my FE guy to get turned yesterday....To my surprise they were within limits and could be safely turned....He made a suggestion that I swap over to roller bearings....I told him I would as soon as I got some 61 to 68 hubs....He said he remembered that there were roller bearings that fit these stock hubs.:confused0006:
I'm thinking I may have heard at the site here that there were a roller bearings that could be used with a stock hub....Anyone else remember or have any info on this?
Discussion Starter · #2 ·
BUMP UP :tu
Do a search, it's been discussed several times.
You have 2 potential problems going this route.
1. Finding those bearings in stock somewhere.
2. If you find them, the price will likely be pretty high.
To me it's far better to switch to the 61-68 hubs/bearings/seals. If you can find a set of hubs, the new bearings are dirt cheap compared to the stock ball bearings or the special rollers that fit the stock hubs.
Try Ebay, Craigslist, vintage salvage yards. Those hubs are out there. If you are patient, you'll come out better.
Of course even better is a proper disc brake conversion.
Did a search.....Found a thread with the info that I was looking for :) http://www.trifive.com/forums/showthread.php?t=44995&highlight=roller+bearings&page=3 Will check into the prices now to see if its worth while till I go to disc brakes.....Here are the numbers, if anyone else is interesred.
Seal: Stock
Inner Taper Bearing: LM67046
Inner Bearing Race: LM67017
Outer Taper Bearing: LM11949
Outer Bearing Race: LM11916
Spindle Washer: Stock
Spindle Nut: Stock
Cotter Key: Stock
Dust Cover: Stock
Thanks HR....looks like a good lead :):tu
