1 - 10 of 10 Posts
Which is best to use on areas like the firewall, dash, floor pans,and inner quarter panels. I know sand blasting is not recommended for the body panels. Also has anyone bought one of the blasters? If so, which one would you recommend that I get. Any help would be appreciated. Thanks,
Randy Humphrey
Did you do a search on Trifive? Try "sandblasting", "blasting media" There are many previous threads that address this topic thoroughly.
Jim
Are you aware that soda blasting won't remove surface rust where sandblasting will?
Are you aware that soda blasting has potential issues with removal and and neutralization?
Sandblasting has it's issues too, like accumulation in all the nooks and crannies, as well as warpage on flat panels.
Sandblasting is more aggressive, so it will work faster on the nasty stuff.
In the end, I think sandblasting capability is what you'll get more benefit from. You can sandblast the floor, frame, firewall, dash, inner fenders, and small parts. For the big exterior panels, you have the option of paint stripper and sanding.
Either one is going to require a good air compressor. And a good air compressor is going to serve other needs and power other tools as well.
Great advise Rick. That's what I did (sandblasting). Have not seen any loose sand in the last ummm 26 years. :tu Lloyd
i bought a 200.00 blast pot from northern tool and several bags of glass media. it does a good job + dont get as hot as sand= less warpage. i believe the same company makes most of the blast pots . so just get a pressureized one and dont waste your time with the vacume type
Rick, thanks for the good information. I already have a good air compressor. How do you think the glass beads compare to the sand blaster?
Randy
Rusty,
Thanks for the info about the glass beads. I looked in my Northern Catalog last night and found a 100 lb pressure blaster with 80 to 110 Psi operation pressure. It has 1/2 in plumbing and hose and includes blast hood. Free Shipping. The price was $309.99. The medium glass beads comes in a 27 lb container. How many should I order to start with? I am in the process of replacing complete floor pan and trunk pan. I plan on blasting everything inside of the car first and then the firewall.
Ive used 80 grit on every panel with zero distortion. My sandblaster gun has an 1/8th inch hole so you wont get alot of material blasted at once. I blast at 90 psi. If you were using a gun that had a 1 inch hole blasting at 90 psi you may warp panels, dont know though.
Rusty,
Since you have already made up your mind about the bead blasting, please post the results. Thanks Lloyd
1 - 10 of 10 Posts
