1 - 3 of 3 Posts
Whats the difference between these frames?Are the dimensions different? How do I tell if the motor mounts or any other parts that I have are for a seamed or seamless frame?.
Seamless frame is narrower then the seamed frame.
How to tell if the parts you bought are for one or the other? Unless you have part numbers........... not easily is my guess.
:eek:
member
:eek:
It depends on where you are measuring. I just measured both frames, and the distance between the two rivets on the crossmember is exactly the same at 24 3/8". The width between the frame rails at the firewall is almost exactly the same at about 29 1/8" on the frames I measured.
What is different is the shape of the frame rail immediately behind the crossmember. This would make the mounts fit differently.
I don't know how to tell one mount type from the other either. :confused:.
1 - 3 of 3 Posts
