1 - 14 of 14 Posts
1956 Belair Sedan, Resto-Mod, Many Upgrades
Anybody know what years are good donors for a serpentine drive setup for a SBC 350 Gen 1 GM 350 Crate Eng up to 86? I have AC, and Power Steering.
Thanks in advance...
Rods56
S10 V6's work, that's what's on mine. I think it was an '89 - 4.3. Came off one of those cash for clunker cars back in 2009. Be sure you have a reverse flow water pump.
1956 chevy 210 del rey sedan
forces you to a long water pump and moving the rad to the 6 cylinder position. not worth the headache
There are several different setups
Personally I recommend the models with either the air or air delete on the passenger side.
Related ?
If you are using the truck Serpentine System (mine came from a 93 Chevy Truck) can you use a Sanden A/C Compressor or do you have to use a GM R4 Compressor?
Wayne
LS Tech and Moderator
Related ?
Wayne
The R4 compressor works fine. Unles you have a sanden already nothing wrong with the R4.
Third Gen F body (88-92 Camaro/Firebird) serp brackets with accessories, used, will likely be the most affordable. Brackets are cast aluminum. The Chevy Performance stuff (for nearly $1K) that was posted is the same thing and you'd be a fool to pay that much for it.
See them on thirdgen.org in the classifieds all the time for no more than $100 for the brackets. All you need after that are the accessories themselves which are easy to find at any auto parts store. It is a long water pump deal so as previously noted, a radiator in the V8 position is a no go.
Driver's bracket: https://www.summitracing.com/parts/ado-10105212
Or stuff like this on ebay: https://www.ebay.com/itm/88-92-Fire...=item2cdfe2132b:g:cD4AAOSwh8NbMEiK:rk:13:pf:0
You basically just need the brackets and the pulley/idler assemblies. Could likely find at a junkyard for next to nothing.
1 - 14 of 14 Posts
