1 - 3 of 3 Posts
Hi all,
Been chasing an internal coolant leak, had the intake milled, new head gaskets and arp thread sealant. The engine has a solid flat tappet cam and I have always used the EO/IC moving one cylinder to the next. Trying to save time, I brought the engine to tdc #1 and bounced cylinder to cylinder 1 2 5 7 etc... When I spun 90 deg to bring #6 to Tdc I heard a pop, sounded mechanical. I checked the roller rockers and pushrods rolled on glass, all straight. I was turning the engine by hand, is it possible I was on the wrong stroke when I started, or could I have set a valve to tight and sent it into the piston? After all was checked I adjusted the valves the way I always have and the sound never came back. Any suggestion or advice would be much appreciated. One thought I had was- a rocker was too loose when I was turning the motor over and maybe the pushrod was not in its cup or the tip off center, and the sound was it finding its spot? Don't know
It sounds like you had your cylinder heads reworked. If that's the case it could be a valve spring that wasn't seated in the pocket in the head. It's actually common to hear those noises when you adjust the valves on a new engine. Sometimes it is a pushrod like you described that wasn't quite in the seat of the rocker arm.
Ran the car today and sounded clean, all cylinders even temps and valve train is pretty quite for a solid. Thanks for the suggestion on the springs that's good to know.
1 - 3 of 3 Posts
