Looking at the lokar shifter. Not sure if i should have the tail mount or the transmission mount that has several adjustment slots in it for placement. Is it a matter of preference in the 57 210 mounting or is one better to have than the other. Also would I have to drop the transmission to mount this or can it be done already bolted in place?
Thanks.
Mike
Mike , if you have a bench seat you probably have a forward mount shifter. Rear mount lokars are to far back to fit a bench seat car . I have removed and installed them with the trans in , but its a real pain . You would be better off to drop the rear or the trans down to work on it. Don
