Im doing a Ls/4l60e swap in my 1957 210 post. It came with the straight 6/3sp. I can't afford the steering column swap yet. Do you guys know which floor shifter works well with my bench seat? Also I don't want a big hole in the floorboard. Any help, part numbers, suggestions will be appreciated!
If I understand correctly, at the end of the day you would prefer a column shift. Good floor shifters aren't too cheap and you'd like to stay away from cutting the floor as much as possible. Can you just find a stock automatic steering column and use that until you get the time and money to get the steering column you want?
