We have a 57 Chevy and I installed the side motor mounts 3/4” forward to clear distributor.
Question: There is a ‘bar’ that gives support to the mounting holes to the engine mount. This bar is pushing against the engine mount polyurethane.
My other vehicle and standard side mounts just has a sleeve for the bolt that ties the mount to engine.
Hard to explain in writing just curious if others have this ‘problem’?
Automotive exterior Font Auto part Bicycle part Automotive mirror
Bumper Gadget Automotive exterior Rectangle Auto part
First picture is ‘forward mount’ and instead of a sleeve they used a support bar on top next to motor mount
Second picture used a sleeve for the bolt to mount.
Not sure why but in my case has caused a problem
Maybe those brackets are for use with factory OEM type mounts only? Do you have any instructions or contact the manufacturer/distributor and find our what the recommended mount is..
That is my next step to make contact.
I think I can install a sleeve between the holes and relocate the bar. Shade tree
It just reduces the clearance about 1/2” which is needed in my case. I can’t see any reason for it to be made th it s way.
200 miles today and now time to make adjustments
Thank you
larry
Can you possibly remove a little of the poly on the motor mount where it contacts that bar to help with clearance, but not affect strength? That's the route I'd take as it's the easiest, and wont require completely reworking the mounts.
