1 - 3 of 3 Posts
I have a Sag 441 in my '55 Delray, but as long as I've had the car, haven't had a speedo. The shifter in the car has been jury rigged to sit faoward so that it will clear the bench seat. The result is that the speedo is blocked.
I just bought a new Hurst Comp+ with the special Tri5 handle and the kit for the Sag 441. So I'll be looking to get the speedo functioning again.
I have 225/70R15 tires (26" dia) & 3.55 gear ratio.
Does anyone know the prat number of the correct speedo gear? The diameter and tooth count of the drive gear inside the tranny would help, too.
Speed o info
There is a web site somewhere that might be Speedo.com or something to that effect
Banned
Go to Chevy dealer and tell them you own a 75 corvette with a Sadginaw 4 speed, 3.55 rear axle and GR-70-15 tires. If your parts man is good he can help you. I have the GM parts books they have charts with this info you can get the numbers.
1 - 3 of 3 Posts
