1 - 2 of 2 Posts
Does anyne know of a rear shock cross that is setup to run staggered shocks? One shock in front, other behind the rear end.
I've never seen one. It wouldn't be hard to build one, except that you may have problems clearing the trunk floor. At the axle, I think you could use two left shock/spring brackets, or two rights.
GM has gone around in circles since the early Camaro using this or not using it. Personally I think if there is any benefit, it's tiny, and it certainly isn't going to control true acceleration wheel hop. It might do OK with braking.
Maybe others have something to say.
1 - 2 of 2 Posts
