There you go! Have you had a front end alignment done also?
There you go! Have you had a front end alignment done also?Could this be a wheel balance issue? An alignment issue?
Yes but spring rate will affect what speed the shake occurs. 55 mph is pretty fast relative to most examples of this problem - which is consistent with the high spring rate.Spring rate will not cause shake spring oscillations are controlled by shocks.
I'm sure they're around 10 years old, maybe a bit more. I'll have to go look. the weird thing is that it doesn't do this on asphalt...just that section of concrete highway.just out of curiosity what is the date code on the tires on the car now??
If the tires are 10 yrs old as you indicated in your other thread, yes have the balance checked on the one with presumed missing weights. then put on the new tires you have. you are all ready at the tire shop. get it done.Guys...I am 99% sure I found my problem.
I'm running OEM C7 Corvette wheels in perfect condition so I know they're not cheap out of balance aftermarket wheels.
However, in looking at my passenger side front wheel this evening, I'm seeing a patch where it looks like about 3 or 4 squares of those adhesive wheel balancing weights came off. The patch is not indisputable, but it's awfully suspicious given a few other things that have happened.
I had a power steering pump leak in my engine bay about a year ago that made a huge mess of everything. It was just everywhere...took me like 3 hours to clean it all up! And I had an oil leak at the mech fuel pump block off plate too. Hard to say which one got crap all over the wheels but I distinctly remember cleaning them both up, taking off the brake pads and cleaning the rotors up just to be sure the car would stop (there was nothing on the pads thankfully).
Anyway, on that pass front wheel, there's a long rectangular patch where it looks like (based on the absence of some dirt and mild staining) where there were more weights on my passenger side front wheel. In comparing the number of square weights on my driver's side front wheel...I see about 8 or 9 of them and on the pass side now, there are only 3. Not definitive evidence, but it makes me very suspicious that the pass front wheel is out of balance. If it is, that's most likely the cause of the shaking problem that happens at higher speeds.
I just never thought of the weights coming off...they may not have been stuck on very well to begin with knowing some car tech places these days, but in light of the two leaks I had, I can't blame them either.
I'm gonna pull the wheel off and take it in to have it's balance checked. Think I'll do them both actually.
I'll post up a report after I get the front wheels checked out.
Yeah...I think I may just do that.If the tires are 10 yrs old as you indicated in your other thread, yes have the balance checked on the one with presumed missing weights. then put on the new tires you have. you are all ready at the tire shop. get it done.
Yeah that's my plan. Like I said, I'm 99% sure this is the problem (i.e one wheel being out of balance). I finally got the heater core out of my brother's '67 Corvette (man, what a job...took me ~5 hours just to get it out!) so I'll take it and my front wheels/tires and my new tires off my '56 in this next week to have it all done at the same time. The local radiator shop is also a general repair/alignment shop.At least if you replace the tires & rebalance you can eliminate tire wheel as an issue causing the shake.Not saying either is the cure but if changing the tires is planned why not now?
