Need some help on a fuel issue on my 55 chevy 327 engine. I have a Stewart Warner 240-A-12 electric fuel pump with 3/8" line to carb. The sending unit is bad and is a 5/16" so I purchase a new 3/8" sending unit to match the main line. I permatexed the sending unit in and ran new 3/8" line to in on electric fuel pump all ok. I turned pump on and it just sits there and pumps like mad and vibrates the back end of the car, so i let it run about 5 minutes or so and looked at carb see thru filter and just a little fuel is there. This unit used to pump pretty fast then slow down to norm as the fuel reached a good head pressure I assumed, now I am lost like the pump is air locked or not primed. I took filter out of bowl at bottom of pump and seems ok, so tried again, there is 1/4 tank of gas as well. At the top of pump is a threaded like weep hole and nut that should tighten what ever this does. Is this a bleed issue? Looking for a service sheet on this pump as well. What makes me mad is pump did work before I changed sending unit, well fuel gauge now does work so that is fixed. Well that is my problem and thanks for any advice.
Steve, it sounds like maybe your pick up screen came off inside your tank when you installed your sending unit. Just a thought.
Discussion Starter #3
Thanks for the reply, took sending unit out tonight all ok, put back in and I primed the pump and used a squeeze bottle of gas and filled lines best I could, pump took off and hammered for just a bit then settled in to norm. Test drove the ole 55 to the gas pump and filled up all ok, thanks for advice. later Steve
Discussion Starter #5
I just got this about eight month ago and the fuel pump is located in the tire well and has a heavy chrome lid over the opening to enclose the pump and well. Steve
