I saw a tri 5 wheel on ebay w/a starting price of $50.Its a welded wheel but I forgot what year they say its for.Whats the difference between welded Vs riveted?(besides the obvious welds & rivets)
I have some welded wheels,some w/4 hubcap nubs and some w/3 nubs.
Some 14" some 15" I know that 57s came w/14s and 55,56 came w/15s but beyond that how do you tell one from another?Is there a code on the rims somewhere?
There is a member here looking for original 55 rims w/the nubs for a full size hubcap.What/where are these nubs?
Yes,I googled,Yes I searched here and I keep getting posts that tell what rims besides factory will fit but not what makes a tri-5 rim a tri-5 rim..
My original 56 wheels have 4 nubs to retain the full sized hub caps and are welded. That means that the center portion of the wheel is welded to the outer rim on the back side.
fred
the nubs are on the 15 on the outside lip to hold the hub caps on .that abput all i know figured it out when the hub caps fell off the wagon just backing out the garage. hope this helps:)
RIP: 10-27-2018
Fred,
No code that I know of, that came later.
55's came with 15 inch riveted wheels, but I have seen some late ones with welded wheels, No way to know if they are original or not.
56's are welded 15s
57's are 14 and they have a deeper reverse, (you remove the tire from the backside)
I believe all were 5 inch width
I have never seen a tri five wheel with anything but 4 nubs but I am learning every day.
What are you asking for the wheels? I need one 15 inch I don;t care if they are welded or riveted.
Gary
Here is an original welded wheel from my '56. You can see the four nubs for the full wheel covers in the picture. There is also a code that is only visible with the tire off. Most of the parts on this car are from July 1956. I believe the G6 stamped on the wheel is for July '56.
RIP: 10-27-2018
Yep, learned somethin new again today. I never knew there was a date stamp inside. Thanks
Gary
Fred,
56's are welded 15s
Gary
Gary,I will send you a wheel for the shipping cost.Lets make sure that I have what you need.Give me a call..386-788-4874 Oldfart
