1 - 3 of 3 Posts
I'm posting this as a heads up. Don't buy the Calibre .4mm or .8mm Gasket Paper, commonly stocked by Supercheap. I had to replace all that I used it on on the Nomad cooling system, ie water pump cover. flanges and thermostat housing. I couldn't understand where I was getting coolant leaking from, so after removing all, I found that the coolant was seeping through the gasket material. I replaced all with Sealite gasket paper so hopefully all well.
FYI I only used the Supercheap variety only because everyone else closed on those early days of Covid 19 lock down.
1 - 3 of 3 Posts
