Elec question ?
Can anyone tell me how you can check out the Mallory unilite module is working ?
lost the spark to plugs, but have a good spark from HT lead from the coil..
Cheers Zody
could try ohms reading on it
one time my 57 died in the driveway(lucky me). put a new module in and was good to go. those little suckers are kind of pricy good luck.
Now sorted...thanks to corroded resisster wire found ! after all that module problem,,it turned out to be bad wiring ??? I take it back what said **** about Unilites !!!
Zody (there used to be stores in SoCal called Zody's)
If you go to Mallory's web site, they have the complete stuff on how to test your Uni-Lite module.
The standard part is number 605 and they are pretty pricey at about $75 or so. Mallory also makes a # 6111 that is a cheaper replacement.
A trick that I use is buying used Unilites on Ebay to get a module, then buying the Mallory mag pickup and putting in the one taht I took the module from, then reselling the unit on Ebay. I get a module and usually make a few bucks reselling the disributor.
I have never had one fail, but I always carry a spare...just in case.
