I'VE DONE THE SEARCHES AND READ THE POSTS AND ALL THE CHARTS AVAILABLE ON THIS SUBJECT AND I'M STILL NOT SURE. IS THERE ANYONE WITH A 55, 15X7 CRAGAR SS MAGS, 4-1/4 OFFSET, FRONT WHEEL DISC BRAKES, REAR WHEEL DRUM BRAKES. IF YOU'RE RUNNING THIS SETUP PLEASE TELL ME THE SIZE TIRES YOU HAVE. I REALLY WOULD APPRECIATE.
How much did your disc brake conversion kit move your wheels out? That answer will help you get advice.
I THINK I'LL BE OK ON THE FRONT. I'LL BE RUNNING SMALLER TIRES THERE. MY MAIN CONCERN IS THE REAR. IF THE TIRES ARE TOO BIG, I'LL HAVE A RUBBING PROBLEM OR CAN'T CHANGE A FLAT WITHOUT A PIT CREW. I'VE READ PEOPLE RUNNING REAR TIRES ANYWHERE FROM 235X70X15 TO 295X60X15. I DON'T KNOW HOW MUCH THESE SIZES CAN VARY WITH DIFFERENT BRAND MAGS. THAT'S WHY I'D LIKE ADVICE FROM SOMEONE RUNNING MY EXACT SET UP. THANKS FOR YOUR REPLY.
15X7 with 4.25 bs is pretty standard. You don't have to find someone with your exact setup.
Since the really wide tires wouldn't be used with a 7" rim, you will be fine with pretty much any size you put on those wheels.
Take a look at this calculator.
http://tri-5.chevyrides.com/rear_tire.php
You can put 255/60-15s on it and they will fit. But those are really kind of a stretch for 7" wheels. I wouldn't like the way they would look on a 7" wheel.
IMO, 235/70-15s would be the perfect size for those wheels, they would look good and pretty much put it in the middle as far as inner/outer clearance.
They also should be easy to install but it is always better to lift the car by the frame instead of the axle for this.
A 15x7" wheel with the 4.24 BS should go under a '55 with no problems.
Even a 15x8" wheel with the same BS should still be in the ball park.
My 14x8 S/S Cragars with 4.00 BS should go under your '55 with no problems.
