1 - 2 of 2 Posts
I have TPI on my 406 small block. Just got new valve covers and want to understand the positive crankcase ventilation hose routing. I guess my real question is how does the crankcase ventilation work on TPI engines?
Thanks in advance for your usual expert advice.
It depends on your manifold, but it's the same as a carb. Everything behind the throttle plate is a vacuum. A PCV valve in the rocker cover, plumbed to a vacuum source will work. My ramjet has a place in the manifold for crankcase vent to vacuum with a PCV valve between them.
1 - 2 of 2 Posts
