Hi, I bought an external transmission cooler for my 57.
The transmission is 700R4 and the cooler I bought is a "TCI Transmission Cooler, Universal" part number: 13219 from Danchuk.
I will use 3/8 hard lines from the transmission to the radiator core support side filler panel, and from there I will use 2 small hoses to connect the cooler to the hard lines. I will use the cooler alone, since my water radiator is for a manual transmission car.
My question is what kind of metal hard lines should I use?
Would it be ok to use aluminum tubing like this from Summit?
http://www.summitracing.com/parts/SUM-G2538/
Or do I need to use a harder metal like copper or steel?
I hope you can help me with this!
Thanks in advance, Jose Sierra
I dont see why not, why not hard line it direct to cool ?
Hi Randy,
I was thinking to add a piece of hose just to have a flexible link to absorb vibrations.
My idea is to use some nice fittings to make it look nice and clean.
Like the one in the link, but I am not sure if I can use this kind of fittings here. In the product description it reads "... is compatible with low-pressure fluid transfer applications"
What do you think? Would it be OK?
http://www.summitracing.com/parts/SUM-2200075N/ b
Cooler lines
When using aluminum lines make sure weight of cooler is supported to frame oryou could be looking for a breakdown at the most inopertune time. You don't need 3 gallons of tranny fluid under your tires.:bowtier:
You could always use braided hose from the transmission straight to the cooler using them AN fittings at both ends. This is better than having a join in the hard lines and makes it easy to run them from the trans to the cooler.
Hi, thanks to all of you who gave me your advise. My main concern was to know if aluminium tubing and fittings were good enough for the pressure. As I understand from you it is OK.
Of course it would be better with stainless but it costs 54 USD a 20 feet roll. Braided hose would be even more expensive like 75 for 20 feet.
I will use aluminium and fabricate some nice support brackets along the engine so that the lines sit stable. And then I will use about 1 foot or 2 of braided hose for the last part. With the cooler properly attached in front of the radiator. I think it will look nice and be safe.
Thanks a lot!
