Hello guys.
I could use some advice on selecting a proper transmission.
My car, 57 2dr ht, now has a th350 coupled to a 283 4bbl engine.
The rear axle I don't know. but i think its a 3.55. This drives pleasant, just cruising around town is ok, but the motorway is not pleasant.
So I'm thinking about a 4 speed od transmission with lockup.
Often the TH200-4r is mentioned as a good upgrade for the th350, also the th700-R4 is mentioned. The last one does need a shortened drive shaft. On this side auto transmissions are not very common, usually old worn th700-4r's with unknown mileage out of camper vans.
Whats important in an auto trans ?
Often I read claims that the th200-4r and th700-r4 both don't last long in stock form and need to be build.
Here is where my trouble start.
I really don't know what I would need.
My car is still pretty stock, the engine, brakes, suspension and I like it this way. So the trans would have to match these specs.
any thoughts?
This is my third summer with a 700R in my 56 and I just love it and wish I changed it before... Later, Dave
Discussion Starter #3
Did you have to do anything special to this th 700?
Like performance upgrades?
700R4 upgrade
I don't know how much parts to rebuild them are over there. Maybe might cheaper to buy a complete rebuilt trans fom a good aftermarket supplier like TCI, B&M or Bowtie Overdrives. They'd also come with a descent warrenty.Just be careful with tv cable adjustment.:D
Discussion Starter #5
That would indeed be a good idea.
Parts are available, usually directly imported from the US.
Most cars are stick shift around here.
If your gonna look for used 700R4's look for 87 and up there stonger the 2004R is the same length as a turbo 350 bouth are great just geared a little differant from one another.:)
Discussion Starter #7
For the ease of installation I'd lean towards the TH200-4R.
They also should have less power loss.
A th700-R4 would be easier to find over here, still finding a good rebuild one isn't.
So in the end I will have to buy one in the US.
Thanks for the good advice.
Nick
