I just put in a Muncie 4 speed with a new pressure plate, throwout bearing, and a new clutch. Now that I've done all of that, I have a cluncking noise like a rod knocking. I also changed the bellhousing, and the throwout bearing yoke. Any suggestions? Thanks 55210
Senior Member 4 Gold Stars
210, what do you know about the tranny? It could be a bad bearing or broken gear. I would look everything over really good and make sure nothing you have done during the install has gone sour. Clutch fork hitting the pressure plate? A wrong throwout bearing can put the fork too close to the pressure plate and hit as it turns.
