1 - 15 of 15 Posts
Try a paint store that carries auto paint supplies.
Jim
Thanks guys, but I guess I should have been more clear. I need the clips for the inside of the vee it's self. I see that they come with one when you buy it. I have the actual v but it has no studs to mount it. Sorry for any confusion.
My trunk V had the studs cast into them,. You will probably have to order a new V or make some sort of mod your self.
Jim
they are just 4 molding clips with the wires on them(same as side molding clips), East Coast has them for .99 each and as Jim57 said you should be able to get them at a local auto body supply store
Banned
You may need to re-a gust the spring for the correct tension or it can slide inside of the V.
Was thinking the same thing Pete, I`m assuming that he has the V & studs intact, just needs the clips
I think you guys are over complicating, Look at view F and G on the diagram Ang posted, the Belair V is hollow and takes 4 molding clips inside of it there are no Studs or Stubs :sign0020:
1 - 15 of 15 Posts
