1 - 3 of 3 Posts
1969 Olds 442 Convertible/ clone
New ignition switch
New Headlight switch
With Headlights on and with passenger side turn signal selected the Pass side lights flash as they should. But the indicator on the dash is showing that the Driver side lights are Flashing.
With Headlights on and with driver side turn signal selected the Driver side lights flash as they should. But the indicator on the dash is showing that the Passenger side lights are Flashing.
Turn the headlights off and the Dash indicator lights work correctly.
Plan to change Turn signal switch in column.
:banghead::banghead:
Anybody have any other suggestions?
New ignition switch
The turn signal switch is NOT the problem. Part of the dash instrument cluster is not grounded properly.
Discussion Starter #3
Thanks Acardon.
I was hoping you see this post.
Les
1 - 3 of 3 Posts
