6.5. 15 inches. Unknown at 2kI am sure thies is not the issue but do you know what power valve is in the carb and what your vacuum is at idle and at 2000 rpm?
I had thought about that but it only does it under light acceleration in a certain spot. If you go ahead and throw the coals to it, it goes. I may have a little too much jet in the front because it loads up a little if it idles for more than a few minutes . I discover little things the more I mess with it.it’s almost like the pump shot is not lasting long enough to let the carb get from off idle into full throttle.
It’s a 31. I believe it came with a 31I guess the next step is to sort out what squirters are currently installed, and what came with the carb when new. Really large squirters shorten the time of the squirt, smaller lengthens. I am still Thinking you have a pump shot/squirter issue at transition. Either a short pump shot, I.e., linkage not permitting a full shot, or squirters that are two large, so the pump shot does not last long enough to get you past the off idle transition and the main system kicks in.
That’s about gone. I did have one but I think that was improper accelerator pump adjustmentSo it seems to be a lean stumble at 2000 rpm?
