1 - 3 of 3 Posts
Where do I put the wiring harness through the firewall? I t sure would have been nice if they would have made a 2 piece wiring harness, then all you would have to do is run a small wire through the firewall and connect the 2 together. Thanks Deb
I ran the harness on the passenger side, far upper area. I also rewired the entire car so the hole was not being used.
I got the wire through the firewall after I seen that we could unbolt the circuit breaker pull the wire through and re-connect. Deb
1 - 3 of 3 Posts
