1 - 2 of 2 Posts
Working in the engine comparment to get all the wiring done. My new horness for the front does not have the black wire in it for the positive battery to voltage regulator, Is this something that has een eliminated or do I need to add it in.
Looks like in the wiring Diagram the red wire from the horn relay hooks to the same trminal on the voltage regulaor as does the black wire comeing from the battery, Is that correct.
The diagram is showing a black wire for ground from the Gen. to the regulator, I have that wire in the horness, But where does it connect to ground at the regulator, My regulator has rubber gromments where it bolts to the front pannel so I don,t see it being a good ground.
Thanks for the help
Shawn
1 - 2 of 2 Posts
