Water Leaks from Front Doors
3904 Views 25 Replies 8 Participants Last post by  56Crazy
Guys,
My '55 2 door Bel Air lets quite a bit of water in at the front bottom of each door. I don't see any water coming down the door panels so it must be coming in someplace else. How would anyone suggest I trouble shoot and resolve this?
Thanks!
1 - 20 of 26 Posts
Are the J-weatherstrips that go under the top hinge and on the upper front part of the door in place? If not then that is more than likely your leak.
That's The Mystery!
The J Gaskets are in place and they're new and tight, just like all the other strips... Can't figure this out just yet...
Thanks for the reply!
remove the kick panels so you can see whats going on
Do you mean the door panel or the small panel with the vent in it? Thanks
Up from the kick panel you should have a drain tube from the windshield. If these are broken or not there it will let water in. You will have one on each side.
Tom,
Thanks for the heads up on this! I'll check it... I never knew there was a tube in there!
Tony
Tom, I checked my shop manual but can't see where the hose connects on top and where it should be routed. Do you know?
Thanks Again!
The tube will connect in the dash under the front dash trim. And exit out the side cowl area, behind the kick panels.
The connection on top is inside, under the dash? How far from the center of the windshield? And if I take the kick panel piece of upholstery off I should see the tube?
Thanks!
The tubes will be connected to the dash in the curved area on the outer sides. I can look up and see the tubes on my 57 going out the side. I really doubt that is your problem unless you have a bad windshield leak too.
Husker send a PM to Viper, he will have a tech manual to show location
Tom,
I searched for "Viper" but no member with that name comes up...
I was going to sugest the drain tube but like was said unless the windshield is leaking that should not be it. the water for those tubes is from condinsation,
Charlie,
Thanks for the clarification! If those hoses are for interior condensation only, that can't be the problem. It only occurs when I wash the car.
Tom,
FYI 57viper
You can look at tech articles from "57viper" in the tri five library, for future reference.
I will suggest you getting in the car and having someone runwater over it to figure out where the leak is coming from and then go from there.
Are you washing the car or are you going to a high presure wash??? Those things can push water into a new car.maybe your door seals arent sealing.
Just the hose at home in the driveway... More investigation is called for here...
1 - 20 of 26 Posts
