1 - 10 of 10 Posts
Model A's have a similar cover that fits on the wood floor board around the gear shift lever and emergency brake handle. THAT IS NOT WHAT YOU HAVE,BUT SOMETHING CLOSE.
JIM, 56 BELAIR 2DR SEDAN
cover
it kinda looks like a home made starter heat shield i have seen some in the speed parts magazine that look like that
I believe this piece goes down by the motor mount on the shift linkage side of a powerglide car. Can't remember if it goes to the front or back. If you check it out I believe you will find the bolt holes would line up to the motor mount holes on the frame.
Yes it does look like the cover in the assy manual. I will check it out on the car. Seems like with only 2 holes to mount it, it will vibrate. Good place to start though. Thanks
The plate difinitley fits the transmission mount hole pattern. I will try to install it once the engine and tranny go back in next year. thanks for the expert help.
1 - 10 of 10 Posts
