1 - 15 of 15 Posts
1955 Belair
Hi guys
I have a unused after market wire hanging under my dash. I traced it to this (upper) box.
What is it?
Hood Automotive tire Automotive lighting Trunk Motor vehicle
In your picture you have a horn relay on the bottom and a lighting junction block on the top. The junction block is for your headlights, park lights and turn signals.
1955 Belair
Thank you. That’s interesting. The wire is plugged into the front (toward headlight) bottom portion of the junction box. My headlights seem ok. But I have been told that my right directional works intermittently. Is it possible that might be for it?
Not sure which wire you are dealing with but the 4 circuits that go through there are; 1) turn signal, 2) park light, 3) low beam, 4) high beam. There is a color wiring diagram here on site so you can ID exactly which one you are dealing with.
I have attached a 1956 wiring diagram. The blue wire is for the turn signals, violet wire parking lights, tan and green wires for high and low beam headlamps. The 1955 wiring diagram is very similar, but the one that I have does not show the turn signals.
Steve
Schematic Rectangle Font Parallel Engineering
1955 Belair
Bruce thanks.
im gonna reconnect that wire. Does that block require hot lead all the time? I’d assume yes.
1955 Belair
First a thousand pardons. I was referring to hot at the fuse panel, not at the junction box. Hot all the time I meant enabled without ignition on.
second tyvm for the wire diagram that will help a lot, when I get back out to car.
lastly I know it’s after market as it is not in wiring harness.
I have no idea what wire under the dash you are talking about connecting to constant 12v. If you are 100% sure you traced it to that junction block under the hood then it should not be connected to 12v power. Those 4 wires are for lights and run from the junction block back to either the headlight switch (via the dimmer switch) or to the turn signal switch.
1955 Belair
Discussion Starter · #13 ·
Bruce
I was under the dash wiring in a electric choke for a new holly carb. While under there I saw a wire hanging free and saw it went thru the firewall. I traced it to that junction block. All my lights work as they should (high, low beam and parking lights. I do have an intermittent problem with right turn signal. I haven’t gotten to work that issue yet.
My thought was wire that wire to hot lead on fuse panel to determine what it (if anything) it does.
my logic no good? I just can’t figure why that wire is there.
Bruce
If all your lights are working (even intermittently) with that wire not connected to anything it isn't your turn signal problem. It is likely something a previous owner installed for who knows what. Look elsewhere for your problem, It isn't that wire. Take it out or just tape the end off.
1955 Belair
Discussion Starter · #15 ·
Ok thanks I will do as you advise.
BTW if you look or zoom in on my pic, you can see the wire coming up from under the horn relay and up into tan plug on junction block.
1 - 15 of 15 Posts
