member
Generally you can't go over about a 275 tire in the rear which is about 11" wide. So a 10" wheel may be a little wide for it. I think a 9" wheel is too big in the front, because again the largest tire you can reasonably run is too narrow for that width wheel. Also, in both front and rear you have to be careful with wheel offset if you're going to use wide tires.
