First what tranny are you talking about, the 3-spd stick or the PG automatic? The 3-spd will bolt up to the 350 by way of the stock '55 belhousing just as if you were putting in another '55 engine. If the PG the V8 version will bolt up, the 6-cyl will not as the block bolt pattern on the adapter ring is different than the V8. Some say all you would need to do is change to the V8 adapter ring but others say there are other differences in the PG itself, I can't say for sure there. In either case with the stock flywheel or flex plate you would use the stock starter that was in the car.Will a stock 55' belair transmission bolt right up to a small block 350 or is there some sort of adapter plate needed?
-Thanks for the help
Works fine and lasts a long time.But again...why would you want to use an old style, stock starter with the bellhousing mounting ears?
I live in the boonies and I don't worry about it.Works great and I dont worry about the original unit checking out in the Boonies somewhere when I'm on a road trip! If this one does it's easily replaced from readily available sources! Just my two cents. Don
Works fine and lasts a long time. Actually I was trying to answer his question w/o telling him he had to swap to side mounts in order to install a 350 because he may only want to replace a tired engine and not get into a lot of modifications. The old system works fine if that is what he is trying to do.QUOTE said:This gets my vote for best post ever.
hotrodrancher, first welcome aboard. glad to have you on the forum.why is it when someone asks a perfectly valid question someone always says "why would you want to do that" instead of answering the question? This gets annoying. I'm trying to do the same swap and would like to know will a 350 bolt to a v8 ironglide without modification such as flexplate, starter ECT.?
I don't see a problem with that. I have done things that I wished some one would have ask me , why are you doing that?:sign0020:why is it when someone asks a perfectly valid question someone always says "why would you want to do that" insted of answering the question?
Why ask Why? I see a lot of post from Guys that are not sure what they doing. Most of the answers are already here in a post, they just did not know.why is it when someone asks a perfectly valid question someone always says "why would you want to do that" insted of answering the question? This gets annoying. I'm trying to do the same swap and would like to know will a 350 bolt to a v8 ironglide without modification such as flexplate, starter ECT.?
Like any thing it would depend on how good of shape the transmission is now and how he plans to Treated.How long do you think it would hold up with the 350?
May sound silly but when swaping the nose do you still bolt it to the bellhousing or to the block?Works fine and lasts a long time.Actually I was trying to answer his question w/o telling him he had to swap to side mounts in order to install a 350 because he may only want to replace a tired engine and not get into a lot of modifications. The old system works fine if that is what he is trying to do.
I live in the boonies and I don't worry about it.I've taken more than one '57 across country from coast to coast as well as several road trips with others with tri-fives and stock starters were the least of our problems. We had a U-joint fail, a harmonic balancer start to slip on itself, and an automatic that quit shifting for some reason, a radiator blow a seam that I had to fix in a gas station with a torch, and the list goes on. If the stock tri-five starter were to fail and you couldn't get another match you could still get a new starter and change the tri-five nose to the new one, problem solved.
