· Registered
I need to remove my front and rear window stainless trim and windows, before I paint. I have a 55 BelAir 4 door with all the bells and whistles and can't figure out how to remove all the stainless on the rear window, the rear 1/4 windows and the top of the windshield......any help would be great, thankyou.
· Administrator
Welcome to Tri Five Bill. The trim will have a screw on each end and then more screws down thru the center section. On the lower they are buried in the whisker strips. On the upper they are behind the rubber weatherstrip.
· Registered
WELCOME
:sign0016:to trifive Bill:shakehands: :anim_25:with the 55... Later, Dave
· Registered
the back stainless is held by a screw in each top corner, pull the rubber seal back and you can see it. onnce you undo them the trim pops off with a little help wiggle it back and forth its held on with clips., carefull not to bend it
wayne
