Finished wet sanding and buffing the passenger door. Now I'm ready to start installing the guts. But, I have a question on the U channel weather strip. I am refering to the lower metal channel that bolts inside with a stud and nut. The metal channel looks to have holes for staples to be inserted (which came with the U channel) and you use the staples (?) to affix the U channel weather strip whisker to the metal. I know some of you have glued your channel in, but I assume this was the upper portions by the window. Or, have you guys also glued the lower portion in? I did finally get three staples inserted, but I wasn't sure if I put them in correct (see pic). The flat back of staple is in groove and I bent the ends on the outside, but will the window hit, rub or rattle against these. Maybe there is more clearance than I think between the channel and vent channel on other side of window.
That's what I was wondering. I thought someone had glued all of theirs. Has anyone used the staples and had the staples interfere with the edge of window?
tj, there is more clearance than you think there would be and I can't believe that the glass would ever hit a staple. The windows do not fit super tight in the channels. I rivited all of my channels and I just put one rivit down towards the bottom of the metal channel and I don't think the glass even gets down that far. I have not have any problems with the pop rivits. Good luck!
Thanks, that's what I was hoping to hear. I'll leave it. I still have to do the other side. But, I want to do them the same.
