R
Guest
Hi everyone...i am ready to remove the rear and front glass from my 57 chev 210 2 door sedan.any help about taking off the clips and the stainless itself would be a great help..thanks Rick
If you put stainless removal in the search in the blue bar at the top of the page it will list a dozen or so threads on this subject. Some very recent.
Good luck.
Jim
There are sticky posts that will help you with that. A shop manual will help you too.
The top piece on both is embedded in a groove in the gasket - the stainless trim is T shaped and fits in the groove. So you can't remove those pieces without removing the glass. You either need to push the gasket off the pinch weld from the inside (if it's still pliable), or cut the gasket with a box knife (if it's hard or you're going to replace the gasket anyway).
In the back, the bottom pieces are held on by spring clips, and they come right off with a putty knife or better yet a tool made for this.
In the front, the bottom pieces are held on by clips and by the wiper escutcheons. Two of the clips are fastened by nuts under the dash. The shop manual is your friend on this.
R
Guest
Discussion Starter #4
Thanks for your help on this part of the project...Rick
the stainless around the back window is held on by clips and the 2 corner pcs that have a nut on inside you have to undo the front top is the one in the rubber seal
wayne
Careful with that knife, when you cut that gasket away, you chip your window glass and it might start a crack. :anim_25:
