Hi All,
I'm looking for the correct replacement wiper motor for my 55 4dr belair. I need to replace it and the control. I will be putting in a 350 engine with electronic ignition and am wondering if the distributor will be an issue with the wiper motor placement. If there won't be an issue then I can purchase any of the quality replacement motors. If there is an issue, is there a smaller or flatter motor or maybe a relocation possibility?
Much Obliged,
Rog
It should not be a big deal. I am running a 350 with a hei dist. It is a full size dist. It can be a hassle , but it fits. There is also a small body hei out there. If it gets to be a problem you can just remove the wiper motor and put it back when you are done.
As far as a wiper motor or repairs, you might try contacting BAM BAM (member).
If you use a Raingear replacement system, it eliminates the motor on the firewall altogether and places it under the dash. It also gives you two speeds and intermittent for more money,
Make sure that the engine mounts are positioned so that the distributor and rocker covers are easily removed from the engine :anim_25:
