I am installing a new stereo in the trunk of are car and I need to know what size wire I should use to run to the ignition switch and to the fuse panel? I have a big power wire going to the the battery from the amp. Thanks again for the help Deb
I'd use #14.
I was hoping that was a good size to us as I have 3 rolls and the wright colour for a change. Thanks again Roger , Deb
What amperage fuse does the radio call for in the instructions?
It's possible that a #16 or even #18 wire would be OK but I think the thickness of the #14 makes it easier to work with and would prefer it anyway. If that's what you have then use it.
