Ok, I got the 'liner in and the front bow won't pull it up to the roof in the center. doe's that mean I have too tight? If so, then I have to live with it?,or will it come around? [vinyl 'liner] Thanks
Danny I assume you have the liner all stapled in with windlace, dome light, visors, mirror mount and garnish molding installed. Don't panic. headliners won't install quite as tight as a nats rear over a circus tent and they tend to bag a little as well. study it a while things always seem to look a little different the next day.
good luck
If the bow is sagging, then yes i`d say you should have dropped the bow down to the lower hole.
Bennie no disrespect meant but that is totally false. If a headliner sags or is baggy then the installer screwed up. No headliner should be loose or baggy.
