Hey all, the build begins! What should be the clearance on the crank bearings? I have the plastigage ready to go and I need to know what it should show.
I had a local machine shop drill my Performer RPM manifold for an oil fill tube on my ’67 Camaro. They got the angle perfect and the tube fits nice and tight. I also had them drill and tap the hole for the heater hose fitting at the same time.Sounds like a plan.
Question: Has anyone drilled out the oil filler neck on the Edelbrock intakes?
I wouldn't even consider doing that with a hole saw. Take it to a machine shop and have then bore the proper sized hole in it, or find one that already has the hole.
Eldon, you seen to be confused.On one hand you seem to want to keep this engine stock-looking, even to the extent of using a stock oil filter with stock colors.....now you're going to use an Edelbrock aluminum manifold. What exactly is the theme of your car?
