I am looking for the cheapest and best way to put disc brakes on my '57. I know that I can order from the vendors, but was wondering if there might be a bolt on situation from a donor car.
Just got off the phone with Aaron at CPP. Seemed knowledgeable about the product and willing to give me a straight answer on all my questions.I don't know the rotor type, sorry. Its always been pretty difficult to get that information out of some vendors -- they view it as proprietary information, and I view that as kind of a joke. If you call CPP they should tell you something, and whatever they tell you will give you a lot of information about where to shop. At the time of purchase I'd want to know exactly what kind of replacement parts I'd be needing in the future, so that I know ahead of time whether I'm going to be locked into a single supplier for replacement parts. Custom replacement parts or overpriced generic replacement parts could make turn an inexpensive kit into a very expensive one over time, and IMO that's as good a reason as any to consider other kits. Good luck.
That kit moves out 3/8" to 1/2" each side, that's the Mcgaughy style spindle with 10.5" rotors. It is a bear to align without offset upper cross shafts also.Anybody using this kit from CPP?
http://www.classicperform.com/Store/1955_1970_Fullsize_Cars/5557CBKD.htm
It only moves the wheels out 1/8" on each side. It doesn't state what size the rotors are. Anyone know that?
I would like to use 4.25 BS 15X7s with 225s and wonder if I could get away with that with this kit. The calculator says no, but just barely.
Are you assuming their online photo is accurate? It may not be.Nothing wrong with up to 1/2" per side for me. I just don't like that style of spindle. It causes steering problems also. I thought CPP had a new style 55/57 2" drop spindle that resembles a stock spindle?(kind of a Heidt's copy). Otherwise the heidt's style is much better.
OK, I'll forget the 8s. But it seems like 7" wheels with that backspace is over the 68 number that the calculator suggests. I know you don't put a lot of faith in that calulator, but wow, that wheel combo you suggest when you go 1/2" per side wider puts you way, way over.I would suggest not using 8" wide wheels up front, save yourself lots of grief.
I usually use 7" with 3 3/4" to 4 1/4' backspace without problems on most any kit.
I want to give you the most accurate answer possible, so I'm going to list my supplier part numbers:Well, I am kind of back to square one now. I would like to be able get 4.25" BS 15X7s with 225s on my '55 with no rubbing. I guess I could go with 215s if I had to.
Bob, will your setup do that? If so, what rotors do you use and are you using stock control arms?
That's an interesting kit and would work for me. Goes to the top of my list.I used the zero offset kit from mgchevyparts on ebay (he's from Cal.) It fit great and was straight forward. I have H-70-15 tires with 3 3/4 backspace and it never rubbed on the fenders before the swap, but just a little on the frame. With the new kit, I have the same. This uses your stock spindle. All steering hooked back up exactly where it came off.
Bob, thank you very much for the detailed analysis. Your setup is on my list and I will study it further.By now I'm sure you've realized that I've typed a lot without directly answering your question. Getting to the point then:
A 7" wheel with 12mm offset should fit a 225 tire safely with my setup, with NO rubbing. .....
