Does anyone have a recommendation for a good steering box grease. I think
it's 90 weight oil days are over.
Thanks in advance.
Thanks in advance.
Well they did, with a service bulletin, I believe in late 1956.If it was good, wouldn't the engineers at Saginaw have specified wheel bearing grease?
I think that you are correct.I will stick with the gear lube. Grease may stop the leaks but, gear oil is a better lubricant. Grease is oil suspended in a carrier such as lithium. Look at over the road trucks, the wheel bearings are filled with gear oil, not grease. I am not trying to compare apples to oranges but, gear oil is the better lubricant.
I am not one that believes in that adage that "good enough" is sufficient, especially if I spend thousands of dollars restoring something. That attitude allows airplanes to fall from the sky. Overkill? Mecum Auction? Jay Leno?I think you are making this too difficult.
Yes, oil may be better than grease, but IMO grease is good enough. After all this isn't a high speed, highly stressed piece of equipment.
Think about the following.
How many steering boxes have worn prematurely and had to be replaced because they had grease in them? Probably very few. At the worst, it's unknown.
How many steering boxes are still in good shape today because they had grease in them? I say quite a few.
How many steering boxes are absolute junk because they had NO lube in them? Many.
Look, it's your car so you will go in the direction you will go. You have read the opinions and seen the paperwork. For nearly 60 years owners have been using grease in the steering box. Some used oil. I myself would never use oil because for the near 40 years I have owned my 57, I have used grease and the stock, original to the car steering box works perfectly and still has the original factory seal. For me, easy is good. If you do decide to use oil, keep us posted as to the oil product you use and your experience with using the oil which will be helpful to others who are deciding which way to go. You may end up being very right!
Pretty well says it all. :congrats::congrats::congrats::congrats::congrats::gba:Look, it's your car so you will go in the direction you will go. You have read the opinions and seen the paperwork. For nearly 60 years owners have been using grease in the steering box. Some used oil. I myself would never use oil because for the near 40 years I have owned my 57, I have used grease and the stock, original to the car steering box works perfectly and still has the original factory seal. For me, easy is good. If you do decide to use oil, keep us posted as to the oil product you use and your experience with using the oil which will be helpful to others who are deciding which way to go. You may end up being very right!
At least for all the shade tree mechanics out therePretty well says it all. :congrats::congrats::congrats::congrats::congrats::gba:
No horse in this race, don't know. Grease worked well for me before upgrading to the CCP500 Box. ONLY time will tell, please post your results. :shakehands::shakehands::shakehands::anim_25: With help from this site, Proud to be called a shade tree mechanic. Thank You LloydAt least for all the shade tree mechanics out there
