I have installed a PRC radiator with dual Spal fans in my 55 Sedan. My battery is mounted in the trunk and I have a heavy gauge (Moroso brand) positive wire going along the frame to my mini starter that's on my big block.
I need a hot wire for my dual Spal fans. I will be using relays and a temp sensor to turn them on an off.
Can I get my hot source off the back of my 100 amp Powermaster alternator or should I run a wire around to the starter? My wiring harness is a stock type from Danchuk that was already upgraded for an alternator.
The harness was bought new in 2001 and and is still good, has only two years of use on it when I had a smallblock.
Also what gauge wire should I use?
