Other than price does anyone know the difference between them?
Do you happen to have a multi meter to check the resistance? They normally run about 40 ohms but of course danchuk says they have never run into that before... every day they say that!Thanks,
Went down there today and they answered my question..... the lower cost unit is made off shore and the thinking is that it should work just fine.... The other unit (more costly) is a US made part.... both are 0-30 ohm...
I will also be adding a ground wire from one of the screws to the frame....
Sorry I have not been on the site in a while ....I went with the "best" as well and the install was a PITA but is now done and the gauge is working as it should.Success!
New sending unit installed with new cork gasket, new screws/copper washers....
Also installed a ground wire from the corner of the tank to one of the tank body holding straps that are welded to the body....
Full tank of gas and no leaks and gauge is working.......
Oddly enough the new sender was making contact at the fuel fitting and was resting against the tank strap once installed.... I had to do some body work to the strap to get them separated......
Glad to check this issue of the "Annoying" list.....
Thanks for all the helpful tips...
What's a AN line up?Sorry I have not been on the site in a while ....I went with the "best" as well and the install was a PITA but is now done and the gauge is working as it should.
The next time I do a sender (when I install a bigger motor 400+ cu in) I will install a new sender and run AN line up.
Agree 100%---miltonI think he is talking about running braided steel line from the tank to the engine with AN fittings.
The one thing that was not mentions is the crappy floats all new sending units come with. Ford has a float that seems to be bulletproof and fits the chevy sending unit. it is Ford part # COAZ-9202-B.
Army-Navy.:gba:What's a AN line up?
Do you have to go to a ford dealer to get that float? I would imagine any aftermarket ones could be just as bad as the ones that rot out now?I think he is talking about running braided steel line from the tank to the engine with AN fittings.
The plastic float I believe is from a jeep approx. 1955 to 1980They wouldn't shoot you if you go to a Ford dealer:sign0020: Maybe Rockauto but I bought mine at a dealer I worked at. I didn't sell Fords but just provided the financing and paperwork.
For some reason the package had 2 floats in it so I sold the extra to someone on CT forum.:bowtier:
