Why do gassers get a straight axle? As I typed, I think I figured it out. Is it just so it can be raised much higher than stock suspension?
That car is the ultimate example of the now age gasser, and nothing can still touch it. I still drool over that one, and can’t believe the owner guy sold it. That’s a ‘forever’ car.
I'd challenge that. My car drives more or less like a stock 55 because aside from being lifted in the front, it uses stock suspension and steering. I run a 205 tire up front as well. Now straight axle cars are a different matter.Have had both,Gassers look cool and draw attention but ain't much of a car in regards to actually driving compared to a proper set up car at normal ride height and a proper size front tire. If you want to build a car that looks better then it drives, a gasser is the ticket.
Challange accepted. 100 bucks says I will stop shorter from 60MPH then you will.I'd challenge that. My car drives more or less like a stock 55 because aside from being lifted in the front, it uses stock suspension and steering. I run a 205 tire up front as well. Now straight axle cars are a different matter.
Nice car. I like your shrunken head. I have on my gasser.One of the things that always caught my attention is that they just looked so damn cool. Two identical cars, one with an axle and one not, the axle car would have me drooling. The other, not so much. At the strip back in those days I would always be hanging around the axle cars....and dreaming of having one on the street. Still am too.
You're on. I've got 4 wheel power discs with drilled and slotted rotors up front and a proportioning valve for the rear in a lightened car.Challange accepted. 100 bucks says I will stop shorter from 60MPH then you will.
It’s not my car, just a pic I stole off the net as an example. I do have a shrunken head though. LolNice car. I like your shrunken head. I have on my gasser.
At one of my customers house they had a thick glass enclosed display cabinet with lots of artifacts, one of them was a real shrunken head. Different for sure, don't see them in the average home.It’s not my car, just a pic I stole off the net as an example. I do have a shrunken head though. Lol
I wouldn't either. Mine is just a little higher than stock, should have gone more. I suppose I could swap springs a third time, actually a forth time.I would not install dropped spindles if they were free.
I have rear coil overs on the rear but plan to have them on the front like the Two Lane 55. My rear tires are way too wide right now (19.5) and future plan is to change that also.Cool, I have 8 inches of rubber on the ground with Wilwood 11 inch rotors up front with coil overs on all 4 corners
All I have to do is look in any mirror to see mine. LolAt one of my customers house they had a thick glass enclosed display cabinet with lots of artifacts, one of them was a real shrunken head. Different for sure, don't see them in the average home.
I have zero interest in their products too. Actually told them that in person in 2017 when they tried to sell me one on Power Tour.I wouldn't either. Mine is just a little higher than stock, should have gone more. I suppose I could swap springs a third time, actually a forth time.
I've said before that I wouldn't install a Dakota digital gauge cluster if it was free and I still feel that way. Way too new looking for my taste, and they don't even have a RED Bowtie for the high beam indicator!
Totally impractical, and that is why it's perfect!I was introduced to gassers as a kid. My dads buddy had a 56 oldsgassed. I always wanted one. 45yrs later.
