What am I missing? The speedometer does not work, meaning the red arm in the speedometer gauge does not move. When I put the car together over the past year I purchased a new replacement speedometer cable and installed it. After the car got on the road and the speedo did not work I unscrewed the new speedometer cable at the transmission and asked my wife to look at the speedo gauge, I then turned the cable by hand from the transmission side and she said the gauge arm moved up. I then removed the part that pushes into the transmission and attached it to the cable and turned the gear and the gauge arm moved up again. As for the gear inside the transmission I can barely see it with the car jacked up on jack stands with a light and mirror and it looks good. I put everything back together and the speedometer still does not work. Any ideas?
