I've searched a don't believe I've see this addresed.
I have a 1955 2DR post with 4W disc brakes. A new M/C with 1" piston & a CPP 7" dual diaphragm booster.
Most of the posts that deal with increased pedal stroke/travel suggest drilling the hole for the booster rod 1" below the original hole for manual brakes. In my case, it seems like it would put the rod between the pedal & booster in a slight bind.
I called CPP and asked their opinion and they agreed to drilling the attachment hole 1" lower on the pedal to increase stroke. But they also said I needed their bracket #5564BB to mount the Booster & M/C at an angle that corrects the pushrod geometry back to a straight line between the pedal & booster.
This is the first that I've heard about this new bracket requirement. QUESTION: Are those of you that have the booster mounted perpendicular to the firewall & the pushrod mounted 1" lower than original on the brake pedal experiencing any problems? Some of the posts suggest a "Z" pushrod that I haven't been able to locate as yet.
My main concern with CPP's bracket is that the front reservoir will be somewhat higher than the rear. CPP did say it wasn't as radical as the Camero's, but still elevated.
Any comments are welcome.
