Going to buy either Old Air or Vintage air under dash unit. Anyone have any suggests on which one to buy. Will be going in a 55 Chevy. Will be getting heat and air unit.
I'm very very happy with my Vintage Air unit in my 56. Top notch tech support, too.Going to buy either Old Air or Vintage air under dash unit. Anyone have any suggests on which one to buy. Will be going in a 55 Chevy. Will be getting heat and air unit.
ThanksI'm very very happy with my Vintage Air unit in my 56. Top notch tech support, too.
ThanksI just ordered an underdash VA hertage series at the show today. I will document the instalation. It came highly reccomended.
PS heat and air.
what brackets did you use to mount under dash unitI'm very very happy with my Vintage Air unit in my 56. Top notch tech support, too.
Mine is the SureFit in-dash model, mounts completely behind the dash (except for the two center vents).what brackets did you use to mount under dash unit
Glove box is not affected one bit on this 56 I just built.I haven't received anything yet, but the guy [vendor], did his dead level best to try and talk me into an in dash unit. There were excuses like your glove box becomes useless, moving gauges, a bunch of jaw time. I know what I want and I will deal with it. One thing for sure, the glove box doesn't make a heckufa lot of difference to me if it is 98* out there like it is today.
the heritage unit is a/c only right?? I installed the same thing @TheHotrodHandyman shows in his pic and moved it over enough to clear my 3 gauge pod and have full use of the glovebox and Floor shifter.I just ordered an underdash VA hertage series at the show today. I will document the instalation. It came highly reccomended.
PS heat and air.
I put in va under dash unit. Summit racing had everything in stockI haven't received anything yet, but the guy [vendor], did his dead level best to try and talk me into an in dash unit. There were excuses like your glove box becomes useless, moving gauges, a bunch of jaw time. I know what I want and I will deal with it. One thing for sure, the glove box doesn't make a heckufa lot of difference to me if it is 98* out there like it is today.
It that air and heat?
A/C onlyIt that air and heat?
No I dontAny pictures?
So you kept the stock heat and defrost? Debating on doing mine that way. ThanksA/C only
Yes, Factory heat & defrost restored and still in place.So you kept the stock heat and defrost? Debating on doing mine that way. Thanks
Sorry for the hijack rdowns
